Hey guys, I recently received a Superpro 24mm heavy duty rear swaybar for my 2011 gu wagon. Also I got the left and right extended links from patrolapart. Only prob is the original d bush saddles are too small, do I need to get different saddles? Does the new swaybar fit in the same spot as the original? Also where the links attach to the chassis there seems to be a removable bracket, not sure if I need to remove them to mount the new longer links. Seems like the new links will hang quite low otherwise.
