Hi, I'm having issues with my glow plugs are not showing up at all on my rd28. like the glow plug does not come up at all...Sorry for the littel info but thats all i know at this stage?
Any ideas???
Any ideas???
Your relay may be up shi*t creek or hopefully just a fuse. Have you got a multi meter to check further into it?
Could also be the globe in the dashboard has blown. It's a bit of an effort, but pull the dash cluster out and swap over a working globe and test it out. Allow about 2 hours for this job if you don't take the steering wheel off! :) I'm too scared to take the wheel off so i wrangle the cluster out between the dash and the wheel. It may look impossible, but I assure you it's doable. Make sure your wheel is pushed all the way down via the height adjustment lever.
