How to know if panhard rod needs adjusting?
The title pretty much sums it up. After my 2" lift, installed an adjustable front panhard rod. What is the best way to know if the front axle has moved and needs adjustment back to center? Will a standard alignment show this or do I need to do something different? Should I also get an adjustable rear panhard?
I know with a 2" lift it doesn't move much, but it seems to have moved a little. I just want to make sure I get it properly aligned and easy before heading out on the winter road next week.
1999 GU RD28Ti; mechanical injector pump, 5kBt Webasto circulation heater, 33" Yokohama Geolander I/T, SaaS boost & EGT gauges, 2" Ironman suspension...more to come
