Getting cold here. Was -26C this morning. Should get another 20 degrees colder in another month. I am pleased my manually fired glow plugs will help the engine start at this temperature especially given that I have no fuel line, filter or tank heaters (I am looking for a fuel filter heater but there are none in this town that I could find).
Anyway, I had to push the truck back out of its parking spot yesterday morning. The transmission would not slip into reverse or fifth gear with the engine started or with the engine off. After pushing it back and driving it forward for about 10 minutes it would finally slip into both 5th and reverse. It shifts smoothly and there is no grinding. But when cold at the start up it does not like to enter either 5th or R.
I was wondering what was happening internally when this happens?
Anyway, the thing is, if I park it in reverse and start it in reverse below -20 it will always go into neutral and back into reverse without any problem even when cold just after starting up and not having been driven. So, I must not forget to park it in reverse. I put a sticker on the dash with "REVERSE!" on it to help remind me to do that.
I should put a winter grade transmission fluid in it I suppose. Same goes for the clutch fluid. It takes a while for things to soften up when below -25.
Soon, though, I'll be walking - hard to get it to start below -28 - I think this is fuel delivery problem; even with winter diesel and antigel below -28 I need a taxi. One time, I poured warm water on the the filter and the fuel hose coming out of the filter to the engine and it started up.
This year, I rented a little garage near my apartment building; so, I think I will eventually park it in there when the temperature is forecasted to be below -30C.
I should have installed a fuel heater in the tank; they sell those here - but it would take more work to install. I have replaced a fuel tank on a car before but that was many years ago.
I was thinking of buying up something like this: http://www.ebay.com/itm/Wolverine-Fu...-/370571136789
This looks easy to install...
I have a couple of thermoelectric generators here (https://en.wikipedia.org/wiki/Thermoelectric_generator). Mine are just like this:
http://www.ebay.com/itm/Thermoelectr...-/291489104250
I bet I could make one of these fuel filter socks myself. Maybe it will provide enough heat to warm up the filter a bit? That wolverine heater may even be working with one of these TEGs inside?
Anyway, better go and start up the car and let it idle up warm given that it is a balmy -24C now.
MT
