Cuppa
Just thinking aloud.
EDIT: Another thought. 1200rpm seems quite low revs to be getting the full whack from the alternator - are you sure you have the correct pulley on the alternator? If not & it were spinning too fast at normal driving revs that could result in the problem you are seeing.
I note you are new here, can you head over to the intro section, it’s generally considered good forum manners to introduce yourself, & you’ll likely find you get a better response. Please also feedback what the story was once you get it sorted. Feedback makes those who try to help more likely to help the next person or yourself should you post again. Good luck getting it sorted.
