3 Questions Front Axle Rebuild Related - tips needed.
Hi Guys,
1. Noticed that I may have created some burs where the inner axle oil seal sits using a seal puller. What is the best way to smooth these out so the new oil seals will go in without too much trouble? Gentle file or emory paper?
2. A bit of corrosion has formed on the axle housing knuckle where the grease wiper seal wipes when swivel hub housing pivots. Similar to the above best way to smooth these out and clean them up?
3. Needle Roller bearing in the stub axle. How in the heck do you guys get those things out? There has to be a more effective way of doing it then they way i do it, which is with a hammer and chisel.
-gazq
