Gday folks, so the other weekend i changed swivel hub seals. Was cleaning everything up and have decided to change the wheel bearings. (next payday) So am cleaning and repacking my CV's with new grease. I found evidence of water ingress namely reddy brown grease. Now below are a couple of photos of what they look like. One of them the ballbearings have surface rust on em the others just stained. Do you rekon this is gunna be an issue? You wouldnt classify as a high speed joint as such would you? Ok its ur axle and that moves fast but is the movement of the CV action fast? Also theres Hot spots on both CV outers where the b allbearins are is this normal?
Cheers all
