Hi everyone, I just like to check something. I now have an ecutalk and noticed that on petrol and lpg my engine goes within 15min to 97 degrees (outside temp 15). It then goes down (starting fan?) to 95 and hangs there.
I have a new radiator, thermostat and viscous hub and found by searching that other people with the tb45 report values of around 87. The temperature sensor is good I think because ecutalk report the correct outside temp (temp when engine starts =outside temp).
Considering overheating in the past, I am a bit worried that the engine still runs 10 degrees higher then others. What you think?
