Good evening, does anyone have the tightening torque specs for the engine to transmission bolts for a Y61 ZD30 to 5 speed box, my Ellery manual doesn't specify.
Thanks in anticipation
Burto
Burto
Not much help but when i did mine ages ago i didnt have a torque wrench so i applied some nut lock goo and did them up pretty much as tight as i could.
look at the back of the manual it shows bolt diam and grades as well as torque settings
there is one for every bolt
120-140Nm according to the workshop manual.
The rear Uni joint nuts on the driveshaft are 94-108Nm in case you need this as well.
