Hi guys,
Noticed a problem on my NA TD42 on a trip to a mates property this weekend. Cant say I have noticed it before, but have now.
Done a bit of a search on here and got some ideas where to start, but thought I would throw it out to you blokes for your input.
Truck is a 89 TD42 non turbo (Auto) with 202000 km on the clock.
What I have noticed is that when under load, say giving it a bit going up a hill it blows white smoke. At least it looks like white smoke in the mirrors
Back off the throttle and smoke clears.
Note : When you hit the throttle, you get the normal puff of black smoke, which clears and replaced with white smoke
If your sitting on a straight section of road, cruising at 80/100km/h no smoke even if you give it a bit of throttle to go up a slight incline or whatever.
- Car is not using water or oil
- No oil in water or visa versa
- Not overheating, sits around 80-85% consistently on long trips
- Oil pressure seems good
- No smoke what so ever on start-up even from cold
- When starting the truck, always starts first turn of the key after glowing the plugs. Starts within one revolution easy.
- Shuts down straight away when you turn it off
- No obvious fuel/injector leaks anywhere
- Fuel consumption is around 18l/100km (seems a bit high to me)
- Is not missing or miss firing
- Doesn't idle rough or anything like that.
- Does not seem down on power (but hard to tell with a NA TD42 lol)
- Head appears to have been done at some stage by previous owner, judging by the new gaskets, Welsh plugs etc. Although cant be sure
- IP was overhauled (replaced with refurbished unit) about 40000km ago by the previous owner.
- Filters all changed around 2000km ago
- No idea on history of injectors
- Cant say what the smoke smells like as had no one following me and does not do it when just idling around
- Always fill up from the same high volume servo and filled up the patrol and land rover on the same day. No issues with the Land rover so figure its not a case of bad fuel.
- Checked the water trap and no water in there
So any suggestions?
I am going to start with some basics and chuck new fuel/air filters in it as well as check the gauze filter (if one is in there) in the IP first. Do a more thorough inspection for leaks etc.
But leaning (lets say hoping) towards the Injectors just need servicing/replacing, rather than head gasket/IP related. Although I will get the IP timing checked.
What do you reckon, anything else to check get looked at?
