with the cyclone coming i should move the gu all the way into the shed. can i move it forward with out the panhard being connected ?
If it's the front should be able to drive it sloooowly for a little bit. If it's rear you will have to push it or tow it or diff will just move sideways when u try and drive. All the best with it - looks a little nasty. . .
It wont steer without the front panhard it will just move the body
thanks just wanted to go fwd 3 feet so all good
Yeah sweet, all good. . . Good luck with the storm mate.
Use a tie-down strap with a ratchet, do a cross tie from the axle to frame , compress springs a litlle ... move carefuly .
