can any one remember ?
There is a post on here that tells you how to ID your diff ,the reason is I'm looking to install a Harrod E locker in a 1999 cab with the td4.2t in it .Also how many splines in that model and a easy way to check would help to get the right diff .
Any other posts on the subject would be appreciated as well because my searches have turned up little so have been putting in dodgy searches .Thanks for your help in advance.
its on your VIN plate I think, good luck
td is it the transaxle eje code
Nisshead would know more but pretty sure all that sort on info
is on the plate, I'll have a look at mine.
Yes you are right read Parksy's post#4
http://www.nissanpatrol.com.au/forum...rol-diff-ratio
Thanks mate spot on info from Parksey and mine is 4.1.1 and all the gu's have 31 spline axles from further research .Thanks for your effort champ.
