Rear back work light
Hey guys, just need some info if any one can help please, just installing a rear work light of the spare rear wheel, how do you guys run your wiring. Do you drill a hole thru the door and run the wiring, thru the rear door and the wire harness? Appreciate some feed back. Cheers
Hi mate for my stainless steel work light I simply use a few rubber grommets to pass the wire threw from mount to door. As in the pics.
Let me know if you'd like some grommets.
I ran mine from the engine bay, along the chassis and up between the rear bar and door.
I have a small hole and a rubber grommet behind the wheel carrier nearly invisable
Thanks guys for the reply, I like the idea of the grommets, Will try and source some around here, Biggqwesty if I cant get any will contact you to purchase some, love the light set up, sorry just bought some close to home from a guy called ferret,
but great set up, looking forward to doing more mods
