Fitting Boost Line
Hello every one I'm about to weld a socket on for the boost line
( Sorry it's a 3 liter ZD Stock exept for exhaust)
I've searched the forum quite a bit and
I'm unsure if I should weld it on the tube entering the inter cooler
Or on the tube exiting inter cooler I welded a bung in for the EGT
Just need the Boost line
For what it is worth:
I had the socket welded to the final pipe--inter cooler to intake manifold. I found laying the hose out where I needed it helped in locating the best spot-plastic engine cover off.
I drilled and tapped (1/4" w) and screwed through the socket into place, so no movement during brazing. I had removed paint on the tube for a clean braze--thin wall so welding was a bit of a worry. I then removed the screw and enlarged the hole through the socket. A quick spray of gloss black and it looks like a bought one. Worked a treat.
Thanks I'll get it welded in tonight Then it'll be wire up the guages
maybe throw up a couple pics as im lookn at doing same thing in a few weeks time.. what brand gauges u end up going with?
I bought gauges from Roadrunner Just got them in today and look ok
Not sure on posting pic's but will have a crack got none of gauges yet
but will try the fitting
https://www.flickr.com/photos/98113380@N08/16516474261/
https://www.flickr.com/photos/98113380@N08/15891688554/
Ended up with boost line just before inter cooler simply because it was easy
if need be can change later
1 Attachment(s)
Here is a completed boost fitting on the upper intercooler to manifold pipe, as noted previously
Attachment 55096
