Hi Guys
I have a 2005 td42t which will not rev much past 2500 revs under load
and in neutral shudders badly at 3000 revs while blowing smoke it finally clears and revs through.
Any ideas
Justin
Hi Guys
Any ideas
Justin
not 100% sure but maybe a start, make sure your air filter is clean and also check to see if your injectors arn't blocked. could also maybe an error with the on board computer not telling what the truck should be doing properly.
Thanks for that i have a mate who has borrowed the nissan plug in for the weekend, if we can reset and get some joy i will let you know!
Dirty fuel possble change fuel filter also a small amount of water in fuel will do this
Sounds like air! Give it a good bleed
