2 Attachment(s)
drivers side electric window
Hi all the GQ drivers window stopped working. when you press the button to wind the window down nothing happens and then if you press up you can hear the motor continually turning until you switch the car off. I tested the motor by disconnecting the passenger one and replacing it with the drivers one and its working fine. The only thing I have noticed is the gear allows you to turn it on the drivers and not on the passenger.
Attachment 50224Attachment 50225
Does this sound like I'm up for an actuator or a replacement amp module?
