Suspension Mods for Towing Caravan
		Hi Folks
I am going to upgrade my stock suspension setup and thinking about an Old Man Emu 2" lift with Nitro shocks and higher rated (200kg) springs in the rear so that when I am towing my caravan there will be less sag and less reliance on my weight distribution hitch to level things back up.
I fancy the 2" lift as it will be handy for when I'm just off road, and also for when towing it will drop the tow hitch lower (relatively) allowing better opening of the rear doors over tow equipment etc.
My query though is: whether to go the OME setup with heavier springs on the back OR to try airbags on the rear.
I wondered if those of you who tow caravans might provided your thoughts on this?
My caravan is 2T, so around 200kg on the tow ball.
cheers
Mark
