Hi all after someone other than "crazyenough" that has mechanical skills.
I've sent up a set of front recovery points and it seems they changed the bolt size on the later chassis.
I sent up a 2nd set but the Laser cutter forgot to include the new measurements.
Long story short need someone to file or die grind the holes out 1mm to suit the later chassis.
ATM the holes are 13mm they need to be 14mm clearance.
