Hey guys just a question about diff ratios
Someone offered to swap diffs with me. He has a gu with 3.9:1 and I run 4.1:1 ratio on my td42 gq wagon. What would this swap do and would it be any good at all? Cheers in advance
Only if your going to run 29 inch tyres instead if 31 inch
Depends on what tyre size you're running but as above, that would be a bad swap.
I'm running 33s atm
if he has some 4.3's it might be a different story.... but 3.9 are really going backwards for you.
Yep Bad deal for you. He is on a winner though ;)
I'd go and punch him in the neck for suggesting such a crap deal.
LMFAO
He wants to swap out the 3.9s for exactly the same reason why you don't want them! They will make yours a Slug mate. You want some 4.3s
You should in technical terms "Kick him in the nuts" for even suggesting the swap. Maybe do the swap if he changes both sets of diffs, and pays for all consumables and gives you $700 odd, so you can then go buy some 4.3's for him to put in.
