1 Attachment(s)
GU shorty rear axle oil leak.
Hi guys
Hopefully a question which has a quick and easy answer...
My shortie is leaking diff oil on the rear drivers side. Is it a straightforward job to replace the two seals? Do I have to replace the bearing as well or can I get to the inner seal without removing the bearing from the cage? The bearing seems fine, no wheel movement or noises so would rather not replace it unless it's necessary. Also I guess, will the diff oil have compromised the bearing and I should replace it anyway?
Nick Attachment 48159Attachment 48159
