I have just picked up a Safari dtronic chip for my 2005 patrol (ZD30).
Does anybody have the install instructions for the chip?
Thanks in advance :smile:
It is not hard to do Deekay,
Make sure vehicle is not running - keys out of ignition
Open Drivers Door,
Look behind centre console adjacent to drivers footrest/clutch pedal,
Find ECU when you look up, and on the bottom is a big white plug, similar to what is on the end of the wiring loom on the Dtronic,
Undo 10 mm bolt and pull down big white connector,
Insert connector from Dtronic Loom into the ECU and do up 10 mm bolt,
Connect the Existing White Plug to the other end of the Dtronic Loom,
Carefully and neatly push Dtronic unit and wiring looms in behind centre console till it is all out of sight
