5 Attachment(s)
Using whats avaliable
Seems to be a common trend for me to never have the right tools for the job so I thought id share a few home made solutions I came up with to conquer the task. It would be cool if others shared theirs also!
Attachment 45718
Spring compressor
Attachment 45719
Attachment 45720
No spill funnel for burping the cooling system
Attachment 45721
Mini keg fire, put a few metre flume on it for a laugh and got flames out the top
Attachment 45722
My flinstones gym
Got a few others but no pictures
Haha love the drill press/valve spring compressor! Flintstones gym is pretty good too where is the car/treadmill device :-P
Yeh, I reccon 4 mini kegs, the drill, and most of the gym equipment, and im sure you could make a car dyno ? (hahaha) :clapping:
Haha now theres an idea!! Im currently trying to sus out a pressure tester jobbie using an old bicycle pump and some coolant lines from an old falcoon.. only issues would be connections, I was thinking wood for the radiator cap with a hole in the center for a hose or fitting.. or I could adapt the pipe fitting I used for the funnel. I just ground down the threads and wrapped in thread tape, worked a treat ;D
solder a 1/4" line to the top of a cap and attach hose to pump/gauge.
Yea I considered that ay but I figured id have to remove the spring and other components but I think thats what allows for an efficient seal.. worth a shot ive got a few lying around
I like that spring compressor idea. I wasted my time using a cheap and nasty spring compressor that took about 2 hours when I never actually thought about doing what you have done.
3 Attachment(s)
Haha yea took me 20-30 minutes once I got a feel for it. I also managed to use a socket and hammer, firm tap. However that was on a doner head that wasnt oiled and had sat around.
I sorted out my coolant pressure tester. I couldnt get the bike pump to seal 100% so I pinched the gauge and hose and set about using a radiator cap as previously suggested. Didnt get pictures of it in action but will tomorrow. Worked well and discovered I have many tiny leaks in my radiator and that my coolant builds no pressure what so ever, I cant figure out why. Despite the radiator leaks which only appear 10psi and over I assume it should make an attempt haha
Attachment 45760
This was going to be the seal but I lost it somewhere in the chaos
Attachment 45761
So I found an alternative
Attachment 45762
