so I have a 92 tb42e and a 07 zd crd now its coolant change time can I use the same coolant in both. also I like using penrite stuff so Is this ok or should I use Nissan and a flush
Have a look at the Evans Waterless coolants Kev
http://www.evanscoolants.com.au/
Cheers,
Rob
The penrite will be fine. Just mix to the correct ratios.
G'day Kev.,
I've used the top of the range Tectalloy in both a 4.2d and 3.0 engine and am happy.
From what I can see the most important part of the exercise is to TOTALLY flush the old stuff out. Particularly if the new is of a different type. If you don't they can react and glue up and the donk's cactus big time.
Luck,
Col.
As above. You can get coolant that can last up to 40,000 Ks.
