Hi all
Will be upgrading my gq steering box to a gu one shortly. As I understand the only thing required for this mod is a new drag link with a gu tie rod to suit the pitman arm taper. My question is will the gq pitman arm fit the gu box? This will make for a straight forward swap plus will save some coin as I still have the original drag link.
I also have a front panhard mount bracket in the shed with bolts and what not, and looking at the bolts, appears that the bracket doesn't sit flush on the chassis. If someone has this bracket fitted to their gq's, can they confirm this? Or take a pic?
Thanks all
Andy
