Hey peeps, I put a new engine in my pootrol (zd30) 2006. Do u have to programme new injectors or recalibrate? If so how?
If it is Di (non CrD) than no need for any interaction with control unit...
Only common rail ZD30s use injector trim codes which need to be entered in the ECU.
how do you put the information into the ECU? What program/OS is used? do you use the obd socket as the interface to get the information in?
If i have to buy another fuel pump, do i have to enter that into the ECU?
Does consult 3 still run on windows XP or has it been upgraded?
