G'day folks
Time to change out the fuel filter on the TD42ti. Popped the bonnet today to have a gander at the filter to see what needs to be done. The primer is awfully hard to move and I see no fuel air bleed on the primer pump.
Oky doky try to turn the primer nob to see if it releases. Hmmph that don't work. Hmm off to the shed to have a gander at me new Max Ellery. Find in amongst me porn stash oops me receipe books. All it says amongst other things is pump primer until hard to bleed air.
Well that tells me to get a can of goodness from the bar fridge an have a think and sip. Shite that's no good all I will end up doin is more sippin than thinkin.
OK this is what I am thinkin The pump is hard to move because there is no air in system and hence full of fuel, The pump will free up once filter or fuel line is removed. To get air out of system open fuel air bleeder on injector pump or just pump primer until hard start engine to bleed air through injectors. Am I a smart cooky or just a dumb arse.:redface:
Your most kindest regards
Gary
