G'day,
I have had a suspension kit from OME fitted in my 2009 GU and bought some 285/70R17 BFG A/T tyres.
As expected, there is some slight scrubbing of the corner of the treadblocks against the rear of the guards - more specifically against the mudflaps and the mudflap bracket.
Because I don't want to remove the mudflaps, risking rocks and dirt being thrown up against the sides of the car, I bought some radius arm spacers that will extend the radius arms by some 15mm or so.
These are set to be fitted on Monday morning together with a caster correction kit (OME again)
By moving the entire axle forward like this, will I need to make modifications to the sway bar links?
I assume they will no longer be vertical.
Roadrunner Offroad sell these: http://www.roadrunneroffroad.com.au/...TB8828ETG.html
