was reading another post but didnt want to hi-jack it so will ask my question here..copied below quote from the post by Happygu regarding the brake bias bracket
"Not for 2 inch lift, as there is enough adjustment.
For 3 inch lift, you should, but you can get away without it and nothing will break, but you may notice a change in brake performance"
I have noticed a change in braking performance in the GQ since I put the 2inch lift in...I have also added a fair bit with bull bar , roof rack , winch , 33's so a liitle bit more weight onto it but I wouldnt think that would drag the brakes back as far as they are..pads seem fine..calipers all working , nothing done to brakes since I bought it....as in any work to them that may have let air in..but definately wont pull up !...I have yet to check the booster ...so what is this brake bias bracket , where does it fit up , and what does it do ?...it has been said , as in the above quote that with a 2 inch lift ..not needed , but I thought I may just have one of those bloody cases where it is ?...cheers
also I havent gone through the process of bleeding them in-case the fluid is that old and lost it's guts...maybe I should continue the process of elimination first !...but it seemed too close to doing the lift
