Water coming in through fan and a/c seal
Hi Guys, wondering if you could give me some advice.
I took off the windscreen wipers, then the grilled panel below, I wanted to pressure wash clean inside the cavity left open after removing the grilled panel that catches all the rain water. It was quite clean just a little dirty. Once I cleaned it I wanted to spray in some wax or fish oil for protection.
The problem is that using a pressure washer it must have forced water into the fan air intake.
As with the GQ`S you have the fan box butted up against the A/C unit, its where the two butt up together water leaked in onto the carpet. I also noticed the air flow knob was set on outside air intake.
Can anyone tell me where the fan air intake is, and there is a slight gap between the fan box and A/C unit. Shouldn`t there be a gasket or sometning there to seal the two.
Guys could you please heeeeeeeeeeeeeeellllllllllllllllllllpppppppppppp.
Much appreciated
Dazza88
