Liquid-moly engine oil resealer
G'day legends,
If anyone has any experience with using engine oil gasket resealer and can release some wisdom in regards to:
Pros,
Cons,
And in particular the liquid-moly engine oil resealer, it would be kindly appreciated.
I have the rd28eti in a 98gu, about 280k on odo.
Even though you wouldn't know it by checking the dip stik she leaves the occasional spot on the driveway:animierte-smilies-f. And it's a little messy on the underside (I know I make a little mess when I change the filter). Oil and filter get changed every 5k +-.
I have found that a new sump gasket is about $100 and rocker cover gasket $75!!!! And a tin of resealer is about $16-20.
Will the resealer work if the leak is only slight?
I apologise in advance if this subject has been done to death already. Please, no liquid-Molly reps.
Cheers.
