Has anybody moved their interior lighting to secondary battery?
Not me, I just fitted LED's to all lights.
Can now leave them on for hours with no worries!
Would be possible if you really wanted to, just find the interior light circuit on the fuse block.
Snip the wire and extend to second battery with a fuse.
Dru
Negative, with led replacements, put the time to better use.
Same here LED replacement be it a bigger brighter light in passenger area.
Rear cargo area has big Led light again and powered from Aux battery via
rear panel with mini toggle switch.
You would be going for a while before your interior globes flatten your battery - on mine it is more like the radio or other accessories.
As others have already mentioned, swap out for LED Equivalents to ease your concerns.
Mic
My whole Patrol is LED and HID, as I like the bright white light and instant on/off LEDs give.
http://www.nissanpatrol.com.au/forum...2013/09/83.jpg
Rear is a fluro with the guts taken out rewired with led strips.
Middle row and rear is LED so far in mine, just need to change driver / map lights over.
