Hi Guys
I managed to round the torx head screw on the maf sensor. tighten it too much last time . does Nissan sell these screws separately or do I need to purchase a whole maf sensor for the screws ?
thanks!
Hi Guys
thanks!
You should be able to buy those screws from a good fastener supplier, you will need to take the old one to match the thread up.
Just take a screw with you and go to bunnings. Who cares if I doesnt have the same screw head. As long as the thread is right.
I tapped that app
yep I might do that. at least will be easy to take on and off during cleaning intervals
thanks guys.
Only tighten it up finger tight too. A hard finger tight. Too tight and you will strip the plastic thread. Also add a little grease around the o'ring to give it the extra seal.
I tapped that app
Yeah I have bad habit tightening nuts bolts too tightly.
