Inner wheel arch gaurds
Hi guys, I'm obviously useless at this as I thought I'd looked everywhere & tried everything but I can't find info on what the plasitc gaurds are called & where I can buy some for the front inner wheel arches of my GUIV Patrol.
I saw in some posts where there was talk about the rubber sheets/gaurds but they're not the ones I'm chasing. The ones I want are a moulded plasic gaurd that protects the inner wheel gaurd from damage. Any help is much appreciated.
Cheers,
Mark.
Try Nizzbits or Patrolapart, bother vendors on here.....
Don't slap it, tap it!!!!
Just curious, what happened to the originals?
Not sure which bits you need ,but if just the verticle skirts ,use insertion rubber from Reece plumbing or similar.
It' 1/8th thick and very tough, used for big gate valve gaskets. 101 uses on a 4x4 and not bad on price too.
Or go to a 4x4 shop and use offcuts from TUB liners TOUGH AS
For the rubber skirts I used Clarkes rubber......still need to pull the old ones off and template them up.
Not sure, it came that way when i bought it 2 years ago. It was a mine car so the underside has required a bit of TLC, just don't want mud settling in the panels & causing rust.
