Morning fellas (and gals if any), Preparing a 4.8 to go into a GQ. I need- manual bellhousing, coil packs, starter, alternator, engine mounts, general engine bolts, and other engine parts for a TB48E. Also looking for LPG ECU and converter/regulator for injected gas. If anyone has or knows someone who has, contacts or info much appreciated.
Wondering whether anyone knows if a manual bell housing from a GQ TB42E will fit onto a TB48E block. According to a guy at 'Marks Adaptors' they use all the same adaptor for conversions throughout the Nissan range including the 4.8. So based on that the GQ bell housing should fit maybe less/more a bolt or 2. I have had a look and measure on my GQ and my recently acquired TB48E, and measurements are different between bolts. Also need to know if flywheels and starters are same.
