Bit of a bug that I see all the time is all the wires from accessories held onto Aux and start batteries with "WING NUTS". Try not to over crowd posts as well. A better option is to use "nyloc" nuts normally 5/16th. A loose connection touring may/has caused fires.Use a nyloc nut and a quick spray of battery terminal stuff.
Loose wires can be the cause of a myriad of problems, use cable ties where possible and cut these with a knife not plyers as the next person to work on your 4x4 will cut himself on the cable tie end. This goes for the battery tray itself , if they bar holding the battery in place only has Wing nuts Change them as well, cheap as chips
