Will a MK lsd h233 diff centre fit a GQ front h233 diff?
I can get my hands on a cheapish mk LSD diff, have read reports of pathfinder lsd's being usedin the fromnt of a gq
Are you wanting an LSD for added traction?
YEP - just an option there have ben posts about guys using a lsd in the front - as the GQ has manual hubs there should not be much wear on the LSD as its only used off road.
The rear won't go. Grab the pathfinder one. For the cost and stuffing around an auto locker would be the go
I thought it was the Navara rear LSD turned upside down that could be installed to the front of the patrol seeing as its 31 spline??
Have a look at this page.
http://nerok.info/differential/gq-parts
and
http://nerok.info/differential/info
Sorry for the dig.
A MK h233b rear LSD will fit into the front of a gq.
I need to drill the ring gear holes on the lsd as the GQ crown uses M14, while the MK H233b centre (lsd) uses M12 bolts
