GQ RD28 starts then stalls... Help?
G'day all,
I've recently had the glow plugs replaced and even a manual switch for the glow plugs due to a suspected faulty relay.
It starts fine, and with the switch will run fine for a bit.
I live out of town and our front gate is at the bottom of a big hill. Sometimes in the mornings as I go to head out onto the road, the engine does its best to die.
Today it was idling low (about 650-700rpm) so I reved it a little to try to fix the idle. As I did it would falter badly and then it ran down and stopped despite my best efforts of manual glow plugs and foot to the floor.
I then re primed it with the hand pump over 10 pumps and got it to start again but then it stalled again and the battery wouldn't let me get a third start out of it.
I've also noticed on gear changes there's a flat spot around 3000 rpm?
Is this likely to be the injector pump?
Lift pump?
Gremlins?
Any advice would be great!
Thanks!
