Any tips on installing an EGT probe before I launch into it? Any gotchas removing / installing the exhaust pipe? Drill and tap the pipe for the probe or drill and weld on a nut? Cheers.
Drill and weld on a nut Hesso . 50mm away from turbo outlet / flange is the ideal .
Welding a nut on is the best option, when I installed mine I needed it done quick so I just drilled and taped mine and it has been sweet doesn't even look like it will ever wrk loose
Same as mine wyld333, my dump pipe is cast not steel so reasonably thick.
