33'x12.5x15 maxxis bighorns, 15x8 rims, 4" lift dobbo med rate coils, efs xtreame shocks,running front tyre pressures at about 28 psi, rears at 26psi unloaded, ive ran these pressures
with two sets of these particular tyres, done a rotation yesturday, noticed 4 lugs on the inside lugs only , 2 lugs then directly opposite those lugs 2 more lugs are wore down 2-3mm more than every other lug on the tyre, this is on all 4 tyres, same spot, gives a vibration through the whole car randomly around 100 ish kays, any one got any input as to what may cause this????
went to bob jane t marts, they were very quick to blame my suspension, i replied with its all new at about the same time including the car been completly rebushed, they still insisted on it been the suspensions fault......and told me i should be running 40psi, when considering the tyre states 35psi max when cold fully loaded...!!!!!!!! oh and the tyres have done 35,000ks, plenty of tread left, only started doing this in the last 5-8000 kays...... rest of tyre wearing pretty well considering..
