Conradk
Just a word of warning with the turbo and general exhaust heat. I've just had a nasty experience with my clutch.
Driving up a mountain track to the highest pub in Africa at 10000 feet (Sani Pass for those of you that know Africa) I started to lose the clutch at around 6500ft and eventually lost it completely around 7000ft. The worst nightmare on a single mountain track with no where to turn around. Eventually found a small place to do a 3 point turn with in gear starts and managed to point the van down the mountain again and drive down without clutch.
Get back to 6000ft and the clutch starts coming back and by the time I was at 5000ft clutch was normal again. Never heard of this happening and neither had anyone else. Put the problem down to an air bubble in the system that opened up at altitude and spent the weekend bleeding the clutch. Problem is I found no air, so I simply replaced the fluid with fresh stuff because the old stuff looked a bit dodgy.
Fortunately I have a laboratory at work so I took the old fluid in for moisture testing and found the water content to be 8%!!! "That's the problem" I tought but could still not reconcile what could cause vapour build-up.
Then finally the penny dropped when I had another look at the workshop manual. My trol had a modified high performance exhaust system fitted and in the process had the heat insulator removed. I ended up having the exhaust pipe almost up against the clutch slave cylinder with no heat protection; clutch fluid with 8% water; and driving up a mountain side in 2nd gear low ration on a boiling hot day (was over 30C). At 7000ft the water simply started to vapourise and no clutch.
I know this is a most unusual occurance but hopefully the incident provides a good learning for others.
