Help needed; gearbox drain plug. Rb30 manual box.
Ok, Chaps. Tried to undo the drain plug, and it started to strip the 1/2 inch hole. Took it to the Mech, and he couldn't budge it. He reckons to grind a short bolt to fit, and weld it onto the plug. Went to a fabricator/ welder, and met a fleet maintenance bloke there. He reckons a 6 inch flat bar with a hole big enough to weld around the lip of the plug is the go. Any thoughts on a better fix?
Also , is the fill plug the same size as the drain plug? Cause I can take it out and use it as a sample to get a replacement one for the drain.
