Hi all,
I have the requirement to wire up 8 LED marker lights, four bright red, four infrared: the amount of power they will draw is absolutely tiny my best calculation less than one amp. Do I;
Option one : just use a switch to turn them on, with a fuse in the circuit to prevent shorting of the cables, if anything goes wrong.
Option two: put a relay in the system and do it " properly" As if it were a set of extra lamps/driving lights/foglamps etc.
Has anybody done this before ? how did you do it ?
Thanks - Zaid
