I am fitting aftermarket speakers to my 02 GU wagon, there is an orange wire & a dark/light strip purple wire for the rear speaker, does anyone know which is the positive?
Check archives must be heaps written on this subject
This thread should help you
http://www.nissanpatrol.com.au/forum...wiring-diagram
I couldnt open the PDF file, when it sorta kinda opened I downloaded half the forum to somewhere but I pm'ed the maker of the file & he wrote back the info I needed, all works a treat now
Got a test light?
But it shouldn't matter which way.
Owner of
Westy's Accessories
Easiest way to check this is a 2 person job, Get a AA battery and tap the wires on the battery, the 2nd person watches the cone, it will either move up or down, If it moves up the polarity is right, if it moves down you need to reverse your wires, as said it does matter as if you have 3 wired right and the 4th wrong it will sound terrible.
This tip was given to me by my uncle who was an old school car radio installer for Strathfield car radios back in the day, never failed me yet!
Cheers,
Eric.
Was going to say there should be a common thing between all of the negatives, and that's the trace.
So all the wires with a trace are negative.
Owner of
Westy's Accessories
thanks guys, learn something everyday
