Trying to remove MAF Unit to Clean
Hi guys just need some help or guidence on to remove the MAF Unit. I know from other posts I'm not supposed to unscrew the 4 small screws.
My issue is the 4 screws attaching the MAF uint to the Air Filter box. When I try to unscrew the bolt the square washers on the inside start to turn as well and cut through the plastic.
Any suggestions how to either stop them from turning or getting the bolts out?
I've tried to hold the washer with needle nose plyers while i turn the bolt but its not stopping the washer from turning.
Please help.
Paul
Re: Trying to remove MAF Unit to Clean
Zd30 2 screws. Real simple. Which engine?
Sent from my GT-S5830 using Tapatalk 2
