Hi fellas, can anyone advise me on correct tyre pressures for road use ? Manual says one thing tyre fitter says another. I have cooper a.t.3' s. 265/75 16.
run what the tyres company says it should be run at, I ran coopersfor 6 years & found them better at 36-front & appx 38-40 at the rear but I carried 4 kids & associated kids stuff, if you are running 30 PSI the tyres will scrub out unevenly earlier & the fronts will scollap faster than normal, I have no idea what the standard is for Patrols
Ok, thanks Morton. Think the manual says 29 front and 36 rear? Seam like odd numbers to me but what do I know ? Some where in the mid thirties sounds about right
I'm running 42PSI front and rear on the same size tyres as per the tyre fitter
I run 40psi
I run 38cold.
42 front and rear
35 on mine, same tyre size as your truck mate.
34..........
As recommended by Tyre shop
Slap N Tap ;)
