Decided to remove the LPG from the GQ and fit long range tank. Anything I need to know? Do I just remove everything non standard?
Not sure of your set up but turn the tank off at the tank first, undo to remove.
Then remove everything gas only related, you may need to block some hoses
with bolts till you can replace them, good time to flush the system ready for summer
with some fresh coolant.
