Anyone heard of this brand of Turbo!
G'day folks!
Has anybody heard of this brand of Turbo "Kinugawa Turbocharger"
The following are the specs i got of e-bay Australia about this product;
Kinugawa Turbocharger: 3" TD05H-16G Nissan TD42 Patrol w/ 6cm T3 Super-Fast Spool
Item location: Saga, Japan
Kinugawa Nissan TD42 Patrol Diesel TD05H-16G Turbocharger with 3" Cover and 6cm V-Band Turbine Housing.
Application: Universal Type- 2000~3000cc gasoline- 3800~6000cc diesel engine
CHRA Size: TD05H-Big16G
Wheel spec: Compressor wheel: 48.3 / 68 mm (EVO3-16G Wheel) Turbine wheel: 49.2 / 56 mm (TD05H / 12 blade)
Compressor Housing: A/R 60, Compressor Inlet: 76mm / 3” - Compressor Outlet: 51mm / 2” - No Anti-surge cover inlet.
Turbine Housing: 6cm / AR 41- T3 Inlet Flange- Internal Gate
Bearing Type: Journal Bearing KAMAK Performance Thrust Bearing Kit
Cooling Type: - Oil and Water-Cooled
Watergate Actuator: - 1.0 Bar / 15 psi- 0.5Bar, 0.8 Bar, 1 Bar, 1.2 Bar, 1.5 bar actuators are available, please contact us if you need it.- Actuator position can be 360 Deg moved easily.
Max Hp: 300~450HP
Turbo Boost Limit: 2.8 Bar (Based on Performance bearing kit with larger thrust bearing)
Suggested Boost: 1.5 bar / 22 Psi
Product Situation: Brand New
Kit Includes: 1 x Oil feed line kit, 1 x Oil drain pipe kit, 2 x Coolant line Kit, 2 x Turbine Gasket ( Inlet + Outlet ) 1 x V-Band Adapter Everything shown on picture is included.
Warranty: One Year
Original price: AU $749.00 Discounted price: AU $711.55
Posts to: Australia, N. and S. America, Europe, Asia, New Zealand $15.00
I am curious for any feed back from those of you with Turbo experience. I am currently in the process of doing a power/torque up-grade on my factory GU 4.2 TD42 engine. I am building up a tourer for towing my camper trailer. I am in the research phase, Is this turbo listed above to good to be true?
I await your advice!
Regards,
RLI
:sterb003:
