power drop when under load ZD30
My Zd30 ddti is suddenly loosing power, then returning after a second or two. When it occurs:
Under load, usually about or above 3000rpm
When exiting a roundabout
After turning left i straighten up & it dies, a cloud of white / grey smoke appears then power comes back
Foot to floor while driving straight it kicks & splutters a little about 3700 up.
What I've done already:
Tested MAF sender-pass
Tested boost sender-pass
Emptied catch can
Checked vac hoses are not pinching & are long enough etc
Checked elec sender lines etc
Zip tied both butterflies in manifold open position
Changed vac lines & sealed intercooler as it had a slight leak.had a better response but not fixed
Dawes valve adjusted to 15psi
Vac lines checked & replaced with better lines
Swapped vac line with better vac source.
Rattle/buzzing from engine but not sure what it is.
Vac pump maybe???
What's the "hg spec for this?
It's pi$$!ng me off!
I'll drain my fuel filter tomorrow but can't see this causing all this.
Any ideas?
