i has anyone every put a tb42 transmission on to a td42?? and will i need to put the td42 bellhouseing on the td42 to make it fit!
the blocks are the same so I dont see why it wouldnt fit could be wrong though
Benny
Yes they can be bolted to them it has been done not sure what is needed though
cheers for the replys! ill give it a go and see what probs. i run in to doing it! ill let use know how it all go!
I think the biggest drama you will have is for the kickdown of the auto. The rest should be pretty straight forward. If it was me I would be manualising the valve body and putting in a TC lockup switch.
I'm sure I read somewhere that all autos are the same, so if your model came out with an auto option, there should be no problem. I could be wrong tho.
