Stabiliser release unit gq
Changing the sway bar links on a 91 gq and at the rear drivers side is a unit called the rear stabiliser release i believe? I have never touched one of these before? and started to remove the four bolts to inspect it and busted a bolt straight up #$%&! So i stopped for the day to think?(drink) I have purchased four sway bar links and figured if i remove this unit a sway bar link must just screw in and out but am at a loss and not sure how to proceed as the manual seems useless and realy would appreciate any advice! Allso purchased some rear sway bar D rubbers of the net and they seem loose,i called the rep and he said they are tapered and i must have them back to front but have never had this problem,they are just rubber not nylothene...
